Temperature Renault 94
Temperature Renault 94 Empty Temperature Renault 94
Message  boegie le Ven 24 Mai 2019, 13:56
I have some problems with the electricity of my Renault 94
Some cables behind the 'gauge' got loosen. In the link underneath you can see a example of the 'gauge' I am talking about.
https://www.google.com/search?rlz=1C1CHZL_nlNL745NL745&biw=1396&bih=612&tbm=isch&sa=1&ei=GtvnXP_2BsXnrgSvtpbgDg&q=jaeger+tracteur+renault&oq=jaeger+tracteur+renault&gs_l=img.3..0i5i30.4647.6631..6647...0.0..0.55.691.15......0....1..gws-wiz-img.......0j0i30j0i8i30j0i24.gqllhbX4shg#imgrc=Ev1RitR8qOg-4M:
The right one for the diesel is working again, the temperature meter isn't working yet
Can someone deliver me a diagram of what cables has to be at the backside of the 'gauge'? Wich are + and - etc.
Kind regards,
Arjen
boegie
Temperature Renault 94 Empty Re: Temperature Renault 94
Message  jb23 le Ven 24 Mai 2019, 21:53
Good evening,
The ATR is able to provide you with all the documentation relating to your tractor: instructions for use and maintenance essential to me to all users, repair manuals and manual spare parts originally intended for repairers, diagrams electric, ... To order just send an email to the ATR indicating the details of the tractor, technical type and Serial No. mentioned on the diamond plate identification of the tractor. By providing the details of your tractor, you will be assured of receiving the documentation corresponding exactly to your tractor. The ATR is alone in guaranteeing you this good supply of documentation which takes into account the evolutions of the product according to the serial number and the evolutions product. A quick response will be made about the availability and price of documents. ATR contact details on the home page of the ATR website.
The engine temperature sensor is an all-or-nothing system that means the system remains inert while the temperature limit is not reached.
Best regards.
Message  boegie le Lun 27 Mai 2019, 12:04
Clear, thank you for the answer.
I will send a mail to the ATR
Kind regards,
boegie
Message  moulino38 le Mer 05 Juin 2019, 23:15
Dear Boegi,
I've got the same tractor than you and the same problem.
first put the wire (see below on the screen shot) to the ground for checking if the gauge move up ( into the red color)
if it's OK then connect the wire at the sensor.
this picture is not very clear I try to send you one better than now
Temperature Renault 94 T_wire10
moulino38
Message  boegie le Dim 09 Juin 2019, 17:18
Thank you for the answer.
Could you make a picture of where the electriciticable you show at the picture is connected at the 'gauge'?
Kind regards,
Arjen
boegie
Message  moulino38 le Mar 05 Nov 2019, 21:41
Dear Arjen,
please find a ( bad) picture of the sensor on the right side :
Temperature Renault 94 Sensor11
moulino38
