120-54 fuel pump timing
120-54 fuel pump timing  Empty 120-54 fuel pump timing
Message  Irish man John le Mer 22 Mar 2017, 23:44
Good evening,
I have purchased a 120-54 Nectra,
The fuel pump was removed long before i purchased the tractor,
My question is do i need a special tool or is there marks on timing gears?
Serial number: R7922 2295305
Many thanks
John
Irish man John
120-54 fuel pump timing  Empty Re: 120-54 fuel pump timing
Message  Irish man John le Jeu 30 Mar 2017, 22:47
Hi, I am also looking for the torque setting for bearings and cylinder heads
Any help would be great
Thanks
Irish man John
Message  Titannyck72 le Sam 08 Avr 2017, 18:13
Good afternoon John , I don't know if you're still enquiring for fuel pump timing .
There are no special method to apply and no more specific tool. As well to the general diesel engine it's necessary to set correctly the injection pump facing  to the front cylinder right position. This one should be adjusted at 6.10 mm to TDC turning in clockwise. The injection pump must be locked thanks to an internal 0.6bar pressure sent by mean of a manual pump connected to the front cylinder pump outlet. The pump gear is written with two marks 2/4 & 3/6. At the coupling time, you mesh one tooth 3/6 facing the two oposite gear teeth noted "0".
About several torque values :
-Head cylinder screws are M14 class 12.9 =  3 daN.m + set with an angle 120° + set with an angle 120°
-bearing screws M14 class 10.9 = 16-17daN.m.
-connecting rod screws M12 class 12.9 = 3daN.m+set with an angle 60°.
Kind regard = Jack72 Cool
Titannyck72
Titannyck72
