Identification Super 3D
Hello,
Do you have information about where and when my Super 3D with nr 7260819 is build?
Frank Daams- Membre Actif
Re: Identification Super 3D
Votre tracteur Renault Super 3 D type technique 7052 N° de série 7260819 a été fabriqué à l'usine Renault du Mans en janvier 1966.
Ce tracteur est équipé du moteur MWM type D 322.2, 2 cylindres à refroidissement par air et injection directe de 1810 cm3 de cylindrée. La puissance de ce moteur est de 30 ch. DIN au régime nominal de 2000 t/mn.
Good evening,
Your Renault Super 3 D technical type 7052 tractor, serial number 7260819 was manufactured at the Renault factory in Le Mans in January 1966.
This tractor is equipped with the MWM type D 322.2 engine, 2 cylinders with air cooling and direct injection of 1810 cm3 of displacement. The power of this engine is 30 hp. DIN at nominal speed of 2000 rpm.
The transmission of this tractor is the Renault transmission with 6-speed gearbox (10 forward speeds if reduction gear), 5th and 6th synchronized speeds. The rear axle is bevel gear and straight final reductions.
The hitch on this tractor is the Renault Tracto-Control hitch with position display and automatic force control via the lower connecting rods.
Kind regards.
Good evening,
Kind regards.
Frank Daams aime ce message
Vous trouverez la pompe d'alimentation de votre tracteur Renault Super 3 D dans une station diesel Bosch.
Good evening
You will find the fuel pump for your Renault Super 3 D tractor at a Bosch diesel station.
Best regards.
Good evening
Best regards.
