Le Deal du moment : -20%
-20% Récupérateur à eau mural 300 ...
79 €
Electrodiag
Electrodiag Empty Electrodiag
Message  Irish man John Lun 06 Juin 2016, 11:12
Good morning all, I recently purchased Electrodiag,
I am wondering will this system compatible with tractonic calibration or do I need another cable ?
Kind Regards
John.
Irish man John
Electrodiag Empty Irish man John / electrodiag
Message  Titannyck72 Lun 06 Juin 2016, 15:38
Hello Seb,
Nice to hear àt you again!
Congratulations ! You're looking as a lucky gui later you've succeeded to find this case electrodiag ...
But I'm afraid it wont offer the possibility to calibrate your tractor with tractonic ! Maybe you'll be able to check the captors values as clutch pedal potentiometer or position sensors or engine speeds but software internally the Electronic Control Unit has changed so many times, that electrodiag is unable to work a tractonic sistem !
The electric box you can also purchase is a tractoshift one especially for the big solenoïd 30 watts12 volts.
I think you have to read carefully at the userbook for metadiag included to the workshop manual. Inside the electric part is discribed the main connectors (2) for each sistem and you will understand that you cannot upgrade such an ECU tractoshift to obtain a tractonic one. Remember to the reverser fully different in both cases.
To permit you to determine exactly what the transmission controller version is, you must open the box and read at the number onto the main processor as V3.1 or V3.2 as well V3 means tractoshift therefor V6 or V7 means tractonic.
Have a nice go on ! Cool
Titannyck72
Titannyck72
Electrodiag Empty par Irish man John le Lun 06 Juin 2016, 09:12
Message  Titannyck72 Mar 07 Juin 2016, 16:53
Hi John !
I am deeply sorry because I did a large confusion when I replied to your last message ... accept my appologies !
In fact at the same time I receive both your messages from a german gui Seb and you !
It looks very strange to get a very similar question at the same time !
Very faithfully, I already have answered your question by the same way if you read at the above information .
In case of none or you need more details please do not hesitate to write to me back again.
Kindly regards = Jack72 Cool
Titannyck72
Titannyck72
Electrodiag Empty Re: Electrodiag
Message  Irish man John Mar 07 Juin 2016, 23:31
Bonjour Jack,
No problem, I am buying the electrodiag off Seb,
I was unsure if it was compatable,
What is the main difference between tractonic an tractoshift, besides the shuttle switch?,
Thanks
John.
Irish man John
Electrodiag Empty electrodiag
Message  Titannyck72 Dim 12 Juin 2016, 12:10
Morning John!
LaterI've received your mail, I did some researches mainly in the workshop manuel (MR 263) and metadoc for more technical détails onto the gearbox front part. Apart the clutch size, two différent hidraulic blocks, more or less one diaphragm inside sinchronisers control pipe unions,twenty bars safety valve, clutch solenoids and controls for reverser(leverswitch with neutral position / ECU) At least it is also a software question as sinchroniser stroke measurment, electrical engagement for clutches progressivity. It means really difficult to upgrade tractoshift/nic or to work the last one with electrodiag ... Considering mr263, that's clear only metadiag computeris made for tractonic.
I hope these informations could help you a bit. In case you need mr263 ATR is able To deliver a french paper version.
Kind regards / Jack72
Titannyck72
Titannyck72
Message  Irish man John Sam 25 Juin 2016, 09:26
Bonjour Jack,
Thanks for your reply,
I didn't realise there was a few difference between the tractoshift and tractonic, I recently purchased a nectar 120 54 restoration project, also I am looking for the timing marks for the injector fuel pump serial number is R7922 2295305?,
Let's hope there will be big celebrations Sunday for us ,
Thanks
John
Irish man John
Electrodiag Empty nectar 120 54 R7922 2295305
Message  Titannyck72 Dim 26 Juin 2016, 11:42
Hello John,
Nice to read at you more!
Relating to the subjected tractor, you must consider the injection pump type : this tractor was built at the time the type number was passing through from 120.14 to 120.54 !
I do not ensure myself with the fact the limited range NECTRA could be 120.14 ? So to answer to your demand, follow the next characteristics
- either the fuel pump type number is R3469F040 => timing shoud be 5.1mm or 21 degrees to TDC
- or the the fuel pump type number is R3462F310 => timing will be adjusted with 6.1mm or 23 degrees to TDC
You can imagine I'll be really enjoyed with a "FREXIT" because I'm fully displeased with football such in that way with euro ... !!! Laughing
Friendly regards = Jack72
Titannyck72
Titannyck72
