Renault 551 Clutch
Renault 551 Clutch
Hello. I have a question about the clutch on the renault 551 tractor with the serial number 5131568. The point is that when driving when I press the clutch, the tractor goes on and only after a while disconnects the gear, and sometimes I have to push the brake to stop. What can it be caused by? can the clutch plate be replaced?
greetings
greetings
technik11- Membre Actif
Re: Renault 551 Clutch
En premier lieu il faudra s’assurer que la garde (jeu) à la pédale d’embrayage est correcte (20 mm) comme indiqué sur la notice d’utilisation et d’entretien du tracteur que vous devez posséder.
Si la garde est correcte et que l’incident persiste alors il faudra envisager une intervention pour remise en état de l’embrayage et traiter les fuites d’huile.
Hello.
Initially it will have to be made sure that the guard (play) with the clutch pedal correct (20 mm) like is indicated on the note of use and maintenance of the tractor which you must have. If the guard is correct and that the incident persists then it will be necessary to consider an intervention for repairing of the clutch and to treat the oil leakages.
Best regards
Hello.
Best regards
» R 55 CLUTCH
