Vidange r86
Re: Vidange r86
Je pense à une butée d'extrémité de tige de culbuteur. Par contre je ne vois pas comment une telle pièce a pu se retrouver dans le carter inférieur moteur, à moins que ce tracteur ait subi une intervention sur le moteur.
Le moteur fonctionne-t-il correctement ?
Re: Vidange r86
Oui le moteur fonctionne parfaitement, ce tracteur était à mon grand père et il a toujours été très bien entretenu et je pense que le moteur a déjà était refait. Le compteur affiche 22000 h
Deloffre- Messages : 3
Re: Vidange r86
Donc affaire à surveiller mais sans crainte particulière.
Continuez à bien entretenir ce vétéran.
Re: Vidange r86
Hello, I'm from Germany and new to this forum. I've been following various posts here for some time, even though I don't speak French. Google translator makes it somewhat possible :-). I own a Renault 88 (R7261-S). This was acquired by my father in 1969. We also owned a Renault 751-4 (R7624-A-L) and was sold in 2001 after the farm was closed. I have restored and repaired the Renault 88 in recent years. Unfortunately, the possibilities here in Germany to get used parts for this rather rare tractor are very limited and it is really always a big challenge. Thank God I have the complete set of documents and can react and search accordingly again and again.
Now my question, I would like to know exactly when the Renault 88 was built? Can you please take a look?
Thanks and best regards
Spock- Membre Actif
Re: Vidange r86
Ups.. sorry for my mistake, I'll write it in a new post about Renault 88 again. It very dificult to understand this forum without frensh!
Spock- Membre Actif
Re: Vidange r86
Hello,
And welcome to the Amicale du Tracteur Renault (ATR) website.
The Renault 88 tractor was manufactured at the Renault factory in Le Mans in 4823 units between October 1967 and December 1971. Tractor No. 6102217 was manufactured during the first half of 1969.
Best regards.
Best regards.
» Super 7 - Vidange Boite et pont - Vidange relevage
» vidange sur 981-4
» Vidange 421
» vidange pont r53
» craquement boite vitesse n 70
» vidange sur 981-4
» Vidange 421
» vidange pont r53
