Renault Super 7 Tractor?
Désolé, je ne parle pas beaucoup de français
I need some assistance with a Renault 7 tractor.
Can you help me with the model please
Model 7093?
Serial Number 0130552
6 speed gearbox
3 cylinder Perkins Engine
Air filter on the right hand side as you look at the tractor
Exhaust on the left pointing down
12.4 - 28 rear tyres
Pictures of tractor
Model 7093?
6 speed gearbox
Pictures of tractor
excossack- Membre Actif
Re: Renault Super 7 Tractor?
Good evening,
Welcome on the "Amicale du Tracteur Renault " website (ATR).
Sorry, In dont speak very well english language.
Obviously we will try to help you for your Renault tractor Super 7.
The first Super 7 was built on september 1961 and the last on may 1969.
Two hydraulic lifting sytems exist on this tractor: first, lifting system 3R or 324, second, Tracto Control lifting from june 1965.
Two engines exist on this tractor: first Perkins engine type P3.152 42 horse power and second Perkins engine type D 3.152 with direct ignition 46 Hp.
Your tractor is a vineyard type of tractor.
For more information we should need some informations on the type and serial number of your tractor: you say type 7093, we don't know this type: Super 7 technical type is 7055; for serial number you say 0130552, this number is wrong. These informations are on diamond plate on the tractor.
It is possible for you to obtain all documentation for your tractor: operation and maintenance guide, technical manuals, engine, gear box, hydraulic... by ATR who sell this original documentation. You can contact ATR by phone or mail signaled on first page of this website.
Evening.
Thank you for the reply. Your English is good. My French - Very bad.
7055 is the correct number i think.
I will ask my friend to check the diamond plate. He is in Spain.
P3.152 i think is correct engine number
How do check what hydraulic system it has?
Is the documentation in English?
Here is a better picture of the tractor. Still waiting for Serial number
Good evening,
With the serial number it's possible for us to know what hydraulic system is on your tractor.
Generally documentation about this tractor is in French only but I think the operation and maintenance guide is iin French and English language; I have to check this point.
When i get Serial number i will post it here.
Thank you for info on the manuals.
Update on the serial numbers, engine, and 3 point linkage
Tractor
Renualt super 7e
Version 7093
0130552 (there is another number on the documents with this 234 10192 103 possible S/N?)
Gearbox 16/12 7700503570
Engine 9/9 669 Perkins 028016
No 152E6742
3 point Hydrualics
32 7700510868
Tractor
Renualt super 7e
Version 7093
No 152E6742
3 point Hydrualics
32 7700510868
ID Badge
Gearbox ID number
Gearbox ID number
Good afternoon,
We are very sorry but your tractor was built in spanish SAMA factory and type and serial number were not the same than in french Renault factory. For exemple the same tractor in France was:
- commercial type: Super 7
- technical type : 7055
- serial number: 75.....
Are you able to give us the manufactory date of your tractor, à photo of the top of your gear box with the gear box lever, a photo of the hydraulic system under the seat. With these informations we could give you the commercial type Super 7 or Super 7 D and the type of the hydraulic system: 3R or Tracto Control.
I have asked for more pictures.
Is there a SAMA Renault forum?
John
John
Good evening,
We'll wait for your pictures.
We don't know if a Sama Renault forum exist but I think no.
Hi Here are some pictures. Sorry for the delay.
i hope these are the correct ones.
thanks
thanks
Good evening,
Thank you for pictures.
Your tractor is à Super 7 D tractor with Tracto Control lifting system. This new lifting system began from october 1965 to may 1969 in France.
Thank you for the reply and for telling me what tractor & lifting system it is.
Is there an english manual for the this model tractor and lifting system ?
Good morning,
About your question, I think no but you have to ask your question to ATR , the mail adress is on first page of ATR webside. All documentation existe in french for your tractor: operation and maintenance guide, repair manual for engine, clutch-gearbox-rear axle, hydraulic lift, spare parts manual...
» SPARE PARTS
» SPARE PARTS FOR RENAULT N73 TRACTOR
» tractor control
» Renault Super 5 ou Super 5D ?
» tractor control
