renault 551 rear axel shaft
Hello. I have a question about the left rear axle. I took out the entire rear axle shaft, removed the tapered roller bearing, and behind the bearing there is a metal ring that is on one side rounded and I do not know why it should serve. could you tell me what role this ring plays? I attach a photo of this ring.
The tractor is a Renault 551 r7451 serial number 5131568
https://i.servimg.com/u/f42/20/01/96/92/img_2012.jpg
https://i.servimg.com/u/f42/20/01/96/92/img_2010.jpg
https://i.servimg.com/u/f42/20/01/96/92/img_2011.jpg
technik11- Membre Actif
Re: renault 551 rear axel shaft
Cet anneau à pour fonction d’éviter l’interférence entre le rayon du cône du roulement conique avec le rayon de raccordement du plateau de l’arbre de roue avec l’arbre de roue car les rayons de ces 2 pièces sont différents. Cet anneau doit être remis en place avant le roulement et monté avec partie arrondie côté plateau d’arbre de roue.
Hello,
This ring with for function to avoid the interference between the ray of the cone of the conical bearing with the blending radius of the axle plate with the axle because the rays of these 2 parts are different. This ring must be positioned back before the bearing and assembled with round part side axle plate.
Best regards
Hello,
Best regards
» Renault 551 front axel
» Drive shaft for S.2
» tracto control shaft on Super 5D
» 160 94TZ rear lift trouble
