renault 155.54
renault 155.54
zdrastvuyte u nas problema s traktorom renault 155.54.zadniy ne vxodit chto mojet bit problemoy . pomogite pojalusta kak reshat problem?
Hello, we have a problem with the tractor renault 155.54 The back does not enter that can be a problem? Help please How to solve problems?
AS GROUP- Messages : 3
renault 155.54
Hello sir,
I feel sorry but I do not understand your question. Could you write down the tractor serial number and tell us the purpose which makes you dismantling the rear axe of this 155 machine ? Have you been sectioning behind the engine or the gearbox ? What kind of transmission was fitted onto this tractor , mechanical or tractonic ? Thank you for your reply.
Regards = Jack72
Regards = Jack72
Titannyck72- Membre Actif
