Renault 180-94 TZ Multishift problem
+2
Tractonic 007
Irish man John
6 participants
Irish man John- Membre Actif
Re: Renault 180-94 TZ Multishift problem
Good afternoon irish man John, to get a quicker answer, i suppose jack 72 (the expert) need to know the blinking Led Light number(default code) to make the good diagnosis. Best regards.
Tractonic 007- Membre Actif
Multishift gearbox faulty
Hi dear John,
Wondering about the trouble you were speaking on a week ago. As well one gui told you , the driving control box could say something linked to what you mind. Facing to each lever position hay one led light on left hand control for senses and right hand control for speeds. These LEDs usely are off in opposite one of it is brightening so indicate whose speed is engaged. But in others words they get a second utility as diagnosis lights. Tell me please which one of the nine speed LEDs is flashing countering from down 1 to top 9 .In that program the 8 other LEDs are on. According to the flashing led determine which circuit or components is out of work.
Thank you to read at you back very soon. Keep safe yourself and family. JACK 72
Titannyck72- Membre Actif
Hi Jack,
Thanks for your reply,
Unfortunately I can’t upload video,
After a few seconds the led lights stop flashing, number 7 stays flashing and the rest will remain lighting
Is there some way I can send you a video to explain ?
Also the control box will function in another tractor but speeds 1,2 ,8,9 don’t work
Hope that makes some sense?
Best wishes
John
Best wishes
John
Renault multishift gearbox faulty
Back to you again this afternoon,
I've understood on what you wrote down your post the led light flashing is the seventh. This code is linked to the controlbox right lever potentiometer. In other words, the locked position for each speed does'nt match with the good value of the potentiometer track as resistance. In ordinary, there is a metadiag adjustment offering one calibration both the nine positions in front the track. Possibly this one could be damaged because of dust or misfunctioning related some crack or short-circuit; I think you're able to remove external plastic cover in the aim cleaning a little bit and check the electrical connections . For information the entire track resistance is around 4000 ohms +/-20% and maybe if you ever had opportunity to do one test with the electronic box, you could do the same with the hand driving box ...
I hope to be helpfull in this case too. Don't worry to write me again as needed.
Keep good yourself and family = Jack72
J'ai une erreur avec les voyants 8 et 3 sur ce tracteur. Que signifient-ils ?
wtechnika- Messages : 2
Et bienvenue sur le site de l'ATR.
Il est indispensable d'avoir le type ainsi que le n° de série de votre tracteur pour vous répondre SVP
alexis BELLEVILLE- Membre Actif
TYPE: R3862E 62K0343
Les erreurs ne brillent pas ensemble. Une fois une fois une autre.
Bonsoir Wtechnika
Bienvenue sur le forum ATR et merci pour vos dernières précisions.
Les LEDs du boîtier de pilotage côté vitesses (1-9) comme vu dans message antérieur permettent une fonctionnalité de diagnostic.
Le clignotement de la led 3 est en rapport avec un défaut autour du capteur de vitesse moteur.
Vérifier l'état de propreté de son extrémité lié à sa proximité avec pignon de comptage. Vérifier un éventuel circuit ouvert ou court circuit sur son faisceau de connexion à l'UCE en testant sa résistance depuis la prise du boîtier électronique (1000 ohms +/-200) ou court circuit du fil retour à la masse.
Le signal de la led 8 est grave et entraîne l'immobilisation du tracteur dans le cas d'un CC de l'alim boîtier pendant l'initialisation. Il traite aussi d'un défaut sur les électrovannes au niveau vitesse lorsque celle ci est sollicitée. Si l'une ou l'autre des électrovannes allure lente ou normale semet en défaut de CC, le signal apparaît et lors de la réinitialisation suivante du boitier, le tracteur est immobilisé quelque soit la position des levier. Attention si circuit ouvert de l'électrovanne 3 risque de mise en route libre.
Bon courage dans vos recherches
Amicales salutations / Jack72
salut, est-ce que le multishift 180-94 est en train de calibrer ????
sisstem- Messages : 1
» Renault 160 94 TZ , pto problem
» probleme relevage renault N70
» PROBLEM DE RELEVAGE SUR UN RENAULT 462
» Problem demarreur 651-4s
» Problem de relevage sur un D22
